74 Charger Wiring Harnesses
Moparmayhem
3:23 PM
Michigan
Hey Everyone, hope your projects are all going good.
My son and I are restoring a 74 Charger and we need all the wiring harnesses.
Ours are all dry rotted, cracked we can't trust them. We're looking for some insight
on brands, where to purchase and some heads up.
Anything will be greatly appreciated.
Thanks,
Moparmayhem
Theorically M&H harnesses are the best option. Being sold throught Year One and Classic Industries.
wait for the Year One 30% discount code they float on every 2 or 3 months I think.
be sure you REALLY need everyone. Tipically the underdash harness uses to get some small damages easy and cheaper to fix than a full replacement. Except if they are heavily hacked by previous owners or mechs.
i can understand the full engine harness AND the NSS harness. They use to be the most damaged ones by the heat and oil. Headlight harness use to be also easy and cheap to fix.
rear tail light harness uses to get some damages just on plug area, and the plug and terminals are available around.
Have to agree with Nacho. He's helped on a few things years back:thumbsup: I did end up getting my engine and dash harnesses thru Year One which sells the M&H harnesses which are exact replicas of the original ones.
M&H is the way to go. Big money but plug and play. YearOne and they have discounts codes to help. Call to see if in stock. .
Thanks guys,
Yeah everything was already tore out and thrown in a box. Don't know if everything is there and if it is for our car.
Inspected the wires, fuse box and they were all chipped and cracked so we just don't get that warm fuzzy feeling. :cursin:
Hey Hanks73340 you wouldn't happen to have a part number and was that a complete set?
What model do you have. Mine is the Rallye version and my 73 will be a little different than the 74. Go to the Year One sight and do a run-down on your model. Both of my harnesses were a complete set for the dash and engine harnesses. I also got my A/C harness from them too.
Thanks,
Moparmayhem
good till midnight monday
Shop YEARONE.com or call 1-800-932-7663
Save up to 30%* until midnight Monday.
Enter Code: UC2235
