Al K
- 1:32 AM
- Nov 15, 2009
Hey folks;need an answer to "what is this piece?" It came off the axle shaft-one of them-that were getting new bearings installed on. The problem is the seal(can't find a listing for one-though I found a PDF file that may help) and the threaded sleeve arrangement that either holds the seal in or is just for the seal to butt up against. What I need is a diagram/schematic showing the breakdown of the axle flange area so I know whether or not I need to take it apart to replace the seal. This is supposedly a 1965 housing,and the axles were in it,so I'm PRE-suming(as opposed to ***-uming) that they are '65 units as well.
I mentioned the PDF file;some of you may be aware of it. I found it looking for rear axle info;Google "Chrysler 8-3/4" rear axle guide" and it should be listed. The resident computer expert is at work,or I'd ask her nicely to link it to here. Lots of dimensional info,as well as parts/seal/gasket numbers. I'm hoping that one of them would be for the seal I need for this piece.
Anyway;if anyone can offer advice(you haven't steered me wrong yet-thanks!),it would be appreciated.
