Mr. Bob,
Actually the MO400 with the snap ring allows for a better axle alignment being that the tubes are rarely square with each other and not always being square with the center housing area. That's the only movement that the bearing will have and that takes place when they are installed and they won't move after everything is tightened. As far as thrust block preload, it's recommended to remove the thrust block buttons when using the Green bearing. Then theres no thrust block contact. The block stays in the spider gears, just the buttons are removed.
The older RP 400 was problematic with this along with not having the snap ring which allowed it to move in and out of the axel tube making contact with the thrust block.
And you would be correct. It's the perfect bearing with having side load and center load capabilities. Rarely do they ever fail unless moisture gets in them. Almost every one that I replaced were rusty and or completely dried out. Then you have the newer vehicles of today that are using sealed ball bearings in almost everything. The most abuse would be front wheel drive units that have the weight of the engine and trans plus the constant weight of turning the vehicle. Most are a double row ball bearing but do alright in most cases. I'm betting you'll have to replace them before you hit 100k miles in a lot of cars. I deliver auto parts part time and they are constantly being sold to the shops everyday.
There's people using the original taypered bearings with their rear disc brake conversions. There was a thread on here not too long ago with a member doing this. It's recommended by most rear disc conversion manufactures to use the Green bearing, probably for the rigidity of the rotor not walking but does a taypered bearing have that much side to side walk? Then you might have to check the alignment of the rotor with the caliper that probably would need to be shimmed if it wasn't true with the adjustable axle side.
I'll try to find those numbers if I can but I would be pretty sure the outcome would be in favor if the taypered roller out lasting the ball bearing. This is almost a given.
The thing is, in this hobby, your not going to drive your classic as your daily driver and get that many miles per year on it. In a normal circumstances don't replace your original bearing with the sealed ball bearing.
The Green bearing is a fix for "out of the norm" situations as what us early car owners have to deal with updating the taypered axel rears or maybe rear disc brake conversions or probably what really started the use of these bearings, Drag racing. Makes it easier to swap out a different gear ratio or replace a unit that just let go with a replacement unit.
I'm using a set of the MO 400s in the '62. Have about 1500 miles on them. I'll be the first to post on here that one failed, I'm not scared!
(I really hope this is the last time we kick this can down the road but I'm not holding my breath.)
