4am and you're on the site.
Bear in mind i am in a different time zone..
Regarding taking advantage of the sales going on this weekend i guess you could buy the camshaft and lifters already if you know what you want/need and as they are the most expensive parts you need, you can score the best discount.
Not long ago i also replaced locks, retainers and springs and i used the below spring compressor.
This thing works very well and can be used with the head installed on the engine.
You bolt this arm in place of the rocker shaft and use that as a pivot point.
Use the original bolts but use some washers to level the tool out as the bolt holes are different depth's.
For removal of the locks a magnet is your friend here, they are small and easy too loose.
When installing new springs you need to play a bit with the tool to get the spring retainer in the right place to install the locks, but you will find out yourself once you get to it.
Just for a reference in case you need it:
1) Set Cylinder #1 at TDC
2) Remove the rocker shaft from the bank by loosening the bolts and lift it out of the way as an assembly.
Store the rocker shaft assy and push rods in the order they came out of the engine to avoid mixing it up or losing/misplacing something.
3) Install the tool over the cyl #1 valves and set it on either valve spring retainer and push down. You will see that the valve hits the piston after a little spring compression, a little "tap" from a small hammer will help in loosening the taper between the locks and retainer without putting too much force on it. (piston is not a steel vice you know)
Now you can push the retainer further down until you can pry out the locks with a small screwdriver or keep a strong magnet near them and you got them.
Slowly release the spring tension and now you can check all parts.
Whatever you do....DO NOT CRANK THAT ENGINE.....your loose valve will drop down and then you got a serious problem.
