Xtro
I have read many threads on operating temperatures and overheating problems and just want to get some feedback on what Im experiencing with my mopar. I have a 1969 Coronet RT with a 440 six pack. I don't know what degree thermostat is in it. If I start the car from cold and let it run without driving it the temperature gets up to about 1/3 on the gauge and maintains that temp. I have a non ralley dash cluster so don't actually know what temperature that exactly is as there are only lines on the gauge. I have let it run for half an hour in the driveway and no problems. Thermo fan does not kick in at all. When I take the car for a drive from a cold start it maintains this same temp for about 20 minutes. The temperature will then start to rise and stay around the half mark and will maintain this temp with the help of the thermo fan. If I drive the car hard (which you can't help when you have a 4 speed manual six pack) the temp will get up to that halfway point on the gauge a bit quicker but still maintains around that mark hovering just over and under half. Getting stuck in traffic with the gauge at this point actually will decrease the temp to under half. Once I start driving freely again it will hover again. Can someone tell me if it is running a 180 temp thermostat is this normal for a six pack. It does not overheat at all but sometimes I worry when I see that gauge creep over half.It has never spit out coolant from the overflow and the radiator level stays constant. Also when I park the car after its been running at this temp and re start the motor the temp gauge is at 3/4 but comes quickly down to half again quickly when I start driving. Should I get this checked out or is it normal for these 440 BB to operate like this. Thanks for any help, view and opinions in advance.
