I have paint and a hardener. But this is a rust spot as big as a hand I want to repair. However, the cost of primer and activator I'd rather not spend. I know, I'm working with chemistry here.
No acetone, let's see a picture of what your working on auggie.I fully tend to either grind that spot or form a patch panel. I just need to ask if there was an alternative to the activator and primer. Like acetone?
Maybe I'll use enamel paint? This car was repainted years ago.
Unfortunately, this computer won't download the pictures I take. Thanks.No acetone, let's see a picture of what your working on auggie.
Alternative to activator and primer (2-stage paint) without killing the wallet. This area is small, I hate the expense of using what the manufacturer tells us to use.
Hard to know what you are wanting help with? Get rid of surface rust with phosphoric acid, and then epoxy prime and then paint. Spending the money on epoxy primer is well worth it.
Can you email a pic with your phone auggie ?Unfortunately, this computer won't download the pictures I take. Thanks.
Ok, if you don't want to use a 2k product then still get rid of all rust and then use the SEM self etching primer like AR67GTX said or VHT, or rustoleum. The 2k epoxy primers in a spray can are not much more expensive than that though. If you want your repair or touchup to last use epoxy. I did a small test area once were I brushed epoxy primer right on top of a surface rusted spot on a panel and it was outside and it help up great. That really sold me on epoxy primer.Alternative to activator and primer (2-stage paint) without killing the wallet. This area is small, I hate the expense of using what the manufacturer tells us to use.
I've never tried but will get back to you when I find out how.Can you email a pic with your phone auggie ?
I can pm you my email address.
My paint shop will mix a color in a spray can if they have a code in their books, but this car is a repaint, might even be an enamel paint job. I have a stock gas cap with the same color. I'll have to get with them and see if they have the tech to see what color this is, to mix and put in a spray can.My paint shop recommended SEM self etching primer under 2k BC/CC for some touch up. Worked fine for small areas. I repainted the rear quarter panel tail light buckets on my car for example.
