GetX'd
Making Life Great Again!
- 4:16 PM
- Jul 20, 2014
- Laguna Beach, CA
Hi guys - I thought I had a dripping oil pan because the bolts were a little loose back when - I tightened them after I put the engine in the car. A while later I noticed a slight drip on the garage floor. Today I got it to a shop where I could get it up on a lift - it seems as though I have a slow leak from the rear main seal. The motor has only got about 2000 miles on it. Which is neither here nor there - I'm just wondering if there's a solution besides the dreaded pull everything out to put in a new seal. I've heard there are additives that you can add to your oil that may or may not stop the leak.
I don't know if that's something to try - if it would gum up the fresh motor - or not. It's a 440 Automatic. Anyone have any ideas?. Not sure what to do. The motor builder is in another state so I'm sol as far as getting him to help. Ideas??
