Anybody running a GERST triangulated rear suspension?
biomedtechguy
Accelerati Rapidus Maximus
7:52 PM
South Louisiana
Comments please from those who DO run any brand triangulated rear suspension.
Thanks!
My experience with a "triangulated" suspension is a ladder bar/wishbone style in a pure drag racing, light car application. Worked great. The GERST system sure looks very sound. Bracket location on the housing seems to be really critical. IMHO
Thanks 66Satellite47....
In another thread, I got a lot of cheerleaders for the CalTracks stuff, but 2 guys who are actually running the RMS StreetLynx system communicated their high regard for it and an enthusiastic recommendation for me.
I was "all in" on the RMS StreetLynx, but after I spoke with Carl Gerst-who I met in person at the 'Nats a couple of years ago, I think his setup may offer a little more adjustability than the RMS setup, and naturally Carl is EXTREMELY knowledgeable.
So whenever the rear suspension system makes it to the top of "the list" and my funds are available, GERST it is!
I am definitely doing the rear suspension before the stroker motor unless I break the motor I have now. Gotta be able to hook first, or a stroker+NO2 motor will just smoke and slide deeper down the track.
Anybody else running a GERST triangulated rear suspension??
Other brand??
There’s a triangulated 4-link under every mustang from 1982 on. The design is nothing new or revolutionary but adapting it to our mopars have opened up options we didn’t have before. Couple it with a really nice pair of double adjustable coil over shocks and you’ve got a great suspension.
@bobtile has a Gerst Front Chassis Components
in his 9 sec. 67 Barracuda
not sure what brand he has out back
Gerst rear tri-4 link system {looks a lot like the Ridetech to me}
this is the Gerst GTS Rear below
$1845-$2295
Ride tech is another
the Pro-Touring guys rave about them
not as racy maybe, looks a lot like the same deal to me
but easily street-able & street/strip worthy
$1400 for a B-body without shocks
there's other or adjt. ends optional IIRC
ridetech 2" adj. coil overs , there's better out there too
or the Shockwave air-suspension, not my 1st choice
the complete kit, it ain't cheap either $5200 for front & rear kit
with the Shockwave air-shocks/bags are pricey,
so are the tank & valves IMO
the rest is reasonable priced, if you do different coil-overs
Disclaimer;
I don't & haven't run either
{I know a few people that did the RideTech}
only a little welding, 4 tabs on the rear axle housing {just like Gerst}
the rest is a mostly bolt on deal
it lowers the car like an 1" IIRC
most all the short upper 4-link, triangulated bars
aren't as good as a real 4-link suspension
{read the short Chris Alston piece in the link}
but far less cutting, welding & fabrication necessary,
let alone real world track worthy adjustability
the big advantage to the triangulated 4 bar/4 link
{GM & Ford style}
is no Panard Bar/Track bar or Watts Linkage {best for handling},
that controls side to side movements
Magnum Force & Chris Alston both make
short upper bar style of 4 links too
Chris Alston Chassisworks
{Generic Universal type kit for a GM I'm sure}
here's a great explanation of how each system works
by someone that knows exactly what they are talking about
I'd listen too & heed his warnings & advice
http://www.cachassisworks.com/stories/techcac-003_web.pdf
short upper bars kit,
so you don't have as much cutting, fab or seat clearance etc.
again not ideal, still a lot of work, cutting welding fab skills etc.
or Ladder bars & coil-overs, panard bar/track bar or watts linkage
X track bar shown
Less cutting & welding involved, than a real 4 link set up
less floor or seat problems
quite a bit of welding still, but not very expensive
Lots of racers still use a tried & true double adj. ladder bar
with great success
{spherical rod ends won't last long on the street 'usually',
albeit I've driven many miles on them, not 50k or something like that,
more like 10k-12k & check them very well & often, or you may regret it}
Magnum Force Racing Pro-Link
Magnumforce Racing Mopar A-B-E body Prolink 4 link coil over bolt in suspension.jpg
Art Morrison Universal type, with a watts linkage
lots of fab & welding needed
{GM Camaro probably in photo} can be adapted easily,
if you have the skills, they may even make a B-Body kit
you'd have to check
QuarterMax RJ Extreme
real truly mega adjustable 4 link mount kit generic/universal
again lots of fab skills & welding involved
like all chassis builder do they make the adj. 4 bars themselves
Competition Engineering 'real' 4 link universal kit,
like $225, lots of fab skills needed
my last RR had Calvert/CalTracs
they work well too, easy peasy install
went 8.58 @ 156, with double adj. Rancho's latter Qa1's
sometime the easiest isn't a bad idea
I'm not saying don't use a 4 link either, but to each their own...
I've debated on going to the RideTech 4 link myself, recently,
If I went to a Strange Dana S-60, latter...
I just recently in the past couple years even heard of Gerst Suspensions...
@bobtile is really why
I'm not knocking them, I just don't know them...
IMO a 4 link is better, if it's a real true 4 link
& you know what you're doing adjusting them
the tri-4 link are OK but not ideal, nowhere near as adj.
but once you get it dialed in you really don't need much adj.
just a flat or turn here or there unless it's really bad track
or you have a bad rear steer problem,
or a huge difference in rollout side to side
just no panard bar/diagonal trackbar
a Ladder bar is an easier fit, for a real racecar setup
if you don't have the fab skills, grinding, cutting & welding is required...
Thanks Budnicks, a really comprehensive look at many of the variety's out there. I am reminded that it is so critical to decide what the "majority" application/use is. The drag racing stuff may not work very well at all on the street(for very long).
What is the advantage of using the Gerst?
Doug
Thanks!
Bio . . . I've been half considering the 4-link application . . . but looking at the setup . . .
You'll have the full weight of the car sitting on the coil over springs/shocks the whole time ? ?
This would seem ( to me ) to be a bit of a short coming of the set-up . . . and potentially a single point of failure ? ?
Am I over-simplifying this and over thinking it ? ? Just my thoughts - ( don't beat me up too much for asking a question . . . )
BIO, that's how a coil over suspension works. The coil is the spring, is just like the leaf spring. Coil overs have the advantage of easy adjustability to make suspension changes.
Budnicks, thanks for the thorough analysis!
Thanks to all who replied!
Doug
Carl GERST was very helpful in answering my questions and his setup for the rear triangulated suspension (according to him) is a little more adjustable than the RMS, and a little less costly.
I want the best range of adjustments so I can get it dialed in right.
Budnicks, I understand your preference for the function of a "true" parallel 4 link, but according to Carl Gerst and a few others that is really for "track only" cars, or at least the triangulated setup is better for a street/occasional strip car, especially for ride quality and handling vs the parallel 4 link. Also the watts or panhard bar uses space where the factory gas tank is, so unless someone goes to a fuel cell in a different location (trunk) that parallel 4 link takes the car further from stock.
If the parallel 4 link was the better choice for my application, I'd do the fuel cell, but I'm being told that the triangulated 4 link is better for my application.
Now all I need is for my bank account to catch up with my wish list.
I was looking at these options. Ultimately, how I planned to use my car narrowed my decision for me. Now that I have my stroker, transmission and in the process of building the Dana 60, i have purchased the caltrac/ split monoleaf setup. My initial thinking was to be able to run Drag Week Big Block/ no power-adder/ Stock suspension class, but after reading the 2018 class rules looks like i would be out due to mini-tubs. The Car will be getting Mini-tubbed and spring re-location next week. I see the pros and cons of each but finally just jumped in and went with initial plan. Car wont see much track time. probably going to get the boot for no cage...yet
Bigfoot, take the plunge & get the roll bar in there now. You surely will need it to run at the track. You have the power to need one. Maybe do the full cage. You will never regret mini-tubs, bigger tires help if you travel to different tracks, plus the bigger tires look cool. Cal Trac mono leaf does seem like a straight forward approach. The Gerst stuff still does look interesting.
Haven't ran any of them but do look at different ideas often, my biggest suggestion is to look at the details. I for one wouldn't like Heim joints for regular street driving and would steer away from anything that doesn't provide a nice solid mounting crossmember for the coil overs. There's a few members on here that are running triangulated four links and have had issues with the joints coming loose and wearing out. Adjustability is great but along with it comes the possibility of things coming loose. I really like the looks of the Magnum Force one that Budnick posted.
I guess what I'm saying is I don't feel like most are built to withstand years of road use and look a bit flimsy.
Something else I've always questioned is the geometry? I'm no expert in any way but my research seams to always show that equal length upper and lower arms are ideal seeing how it maintains a consistant pinion angle but these kits always have stubby upper arms? This leads me to believe the kits are built to be "bolt in" and not so much about being built ideally? Don't know that it's available for Mopars but I intend to built a torque arms rear for mine, very, simple, strong and a better fit for the car IMO. Check out Goon's Angrybird thread, he's having one built for his that looks pretty slick.
Thanks 66Satellite47, will look at cage option when car goes under the knife. trying to stretch my budget, but want to do things right.
Bigfoot, seems like quite a few kits out there & a number of chassis guys around to do an install. Having tubes around you is very comforting. I have experience. Stuff does happen & the tubes really do make things survivable. Budget is something you gave up long ago! Think safe.
Why not just run leaf springs? For 99% of the cars here they're cheap and get the job done. For a dedicated drag car ladder bars would be the choice. But for street/strip/auto cross you have to have a pretty sophisticated car to see enough of an improvement to make a difference. Same goes for the front suspension. I'd spend my money on high end shocks and brakes, good sway bars or Cal Tracks depending on intended usage. Especially if it's a bolt on system . Just my 2 cents.
Doug
Assasin traction bars. They have a ton more adjustment than the Cal’s do.
Thems the ones!! I have them and damn to they make the car plant!
It's great to have a part/combination that works well. What spring are you using? How much work did it take to find the right adjustment? From years ago, the difficulty with with 4 link stuff was finding the proper adjustment. The Assasin setup seems to have a ton of adjustability, but how to get it right. I was really lucky my chassis builder told me the ladder bar adjustment, they were perfect. Too much options could get a person far astray.
