Adam Nathan
Anyone know where or who supplies heater cores for a 70 B body. Used to be an aircon car so I assume I'll need the correct core to fit the heater box. It's a big twin core type so I figure that'll be the most expensive one.
Having just replaced every bush, ball joint, nut+bolt, tyres, starter moter, power steering pump+Pulley, door rubbers, hoses, belts, mirrors, shifter+linkages, cam shaft, lifters, springs, caps, retainers, radiator+shroud, water pump, distributor, coil, plugs, leads, transmission rebuild + new pan, rebuilt cluster with L.E.D replacements and all the other **** I can't remember + the countless hours cleaning, scraping and painting. Finish work and go straight to the garage to put in some more hours, gave her an oil and filter change and just when you think you've finally got there you take the bastard out for a well earned drive the heater core starts leaking.
You ungrateful *+%#}~<€^%{~?€$+**
Ahhh that's better. Thank you.
And yes I know as my dad keeps telling me
"that's old cars for you son"
Guess I got some more hours in the garage ahead of me now with the credit card on stand-by.
