Dave145
The leaf springs are brand new.
Brake drums are brand new raybestos drums.
The pinion angle is fine. -1 degree between tailshaft and driveshaft, +1 degree driveshaft to pinion.
Pinion bearing I would think would make noise. I've had it on stands and run it up to speed and haven't heard anything from the rear end, plus I can crawl under it with the driveshaft off and I can't wiggle the pinion at all.
Front and rear wheel bearings are all new, greased, and properly torqued as well.
Vibration is in the floor and seat.
Tach says it's somewhere between 2100-2300 rpms. Don't remember the exact number off hand.
90% of the time the car vibrates as soon as I hit 70. 10% of the time it doesn't vibrate at all. There's no predicting when it will or won't vibrate, but when it does vibrate it does it exactly at 70 and is felt only in the floor.
