Best dual master for m/w manifolds
crossram 426
6:00 AM
Australia
Looking for best dual master for 63 dodge with m/w exhaust manifolds...Don't want it too close for heat etc. Cheers in advance.
They make an offset bracket for Hemi cars im not sure if that moves the booster & MC closer to the drivers side fender or raises it higher...
I just picked up a complete set up, to convert my '63 Dodge to Front disc, at Carlisle this year. I believe it's the common A-body change over kit, to use on most mid-60's, to early 70's. I've seen these installed on other similar M/W Cars, and they do fit. I do plan to fab a heat shield to keep it cooler.
I just picked up a complete set up, to convert my '63 Dodge to Front disc, at Carlisle this year. I believe it's the common A-body change over kit, to use on most mid-60's, to early 70's. I've seen these installed on other similar M/W Cars, and they do fit. I do plan to fab a heat shield to keep it cooler.View attachment 814833
if I may ask, which kit did you get and from whom? cheers Matt
Matt, I got the kit(s) from Right Stuff. They included Complete Disc change over components, upgraded to drilled-slotted rotors, the M/C, all the brake lines, front to back, and also included the rear axle lines, to fit a Dana, as that is what I'm using. It's supposed to be "plug & play", so I'll find that out. They also included Free shipping to my home, so I didn't even have to lug all the parts back to my truck during the Show. They also had a Nice Show Special Discount going, so I ended up buying another similar kit for my '65 project...
Do you happen to have a part number for the kit? Their website does not list a conversion kit for early B's, at least not for a 64 Dodge.
My 62 Belvedere set up with 4 wheel Willwood Discs. Made heat shield that drops temp by 80%. 15/16" MC bore for correct pedal travel and effort.
I'll let you de-cipher the writing on the receipt:
The # with 62 is for a MW install, the 65 is for BB application.
