I have had the coil mounted in front of the carburetor in a horizontal position for years. This will be in the way of the A/C compressor so I had to move it.
Got the 26” rad installed. Have everything purchased for the AC swap except for belts. I can see the belt part numbers on your PS and water pump belt. Can you let me know the 5 digit number stamped on the 2 AC compressor belts?To be clear, the first shot above is my attempt to run a three-belt big block A/C configuration, as discussed here. It did NOT work for me, belt slipped. Second shot is the same motor running the factory designed 4-belt config, no more slippage.
Here are some more pics of my other big-block A/C installation, better angles.
Goodyear belts were sourced from O'Reilly's, they are cogged belt design but was not enough to stop slippage when the PS pump and water pump were on the same belt.
