Blade's Ego thread: Sculpture, Cars & Airplanes
I am truly impressed with your art. Your finished items have the simple clean look like they are a natural part of nature.
My projects always need "finishing"----I can never get that last part down like you do. (I try). My projects will always be almost done because of that.
Thank You B! Big difference in real estate, these small objects, by comparison to cars, bikes, aircraft etc......gobble up huge amounts of time, proportionate to their size
I probably put something ridiculous like 70 hours into the Sailboat, maybe more.
I look at the machining, try to comprehend the execution, the planning etc of Your bike, it Staggers me.....doesnt look to me like it aint dialed in......made my top ten bbo choices......Sincerely......j
I guess we are talking about apples and oranges here. My frustrations putting a finish on a part usually puts me into a --I'll get back to it tommorow mode.---
You know as well as I what the eye can see in a finish. We are looking at microns here that show up looking like pimples.
I have worked on a Stainless part for days until I finally realize that I need to go back three grits and many hours of work to again move ahead.
When I am in museums and come across shiny metal art I (by my nature) get in close for a look. ...................
The curves and shapes of the art you do is one thing that draws the eye but the quality of the surface finish puts in on the top shelf.----A poorly cut and finished diamond may as well be quartz. Cheers
When I am in museums and come across shiny metal art I (by my nature) get in close for a look. And bingo --95% of the time I see where the artist just said **** it that's good enough.----the shape is good enough---
The metal shaping finishing skills are born of being in straightening & refinishing for past 45 years....i fell in love with the feel of cutting aluminum long ago....it has so much more resilliance than the soft materials used in bodywork. Primers, fillers are a bitch to keep definition in, once shaped , and run through the grits to a finishable surface. The aluminum has a sweet spot temperature where it likes to be manipulated....it talks....too cold it chatters.....too hot it chatters and cuts with irregular cut pattern.....i like my scratch patterns even, consistent. If You saw the aircraft windshield some posts back.....a very critical, arduous process, to maintain tolerance & optics.....light crazing runs 5 - 10 thousandths....when cutting even with 80 grit, it takes about 8 hours to get to bottom of damage.....very slow & tedious...once that is accomplished, it's about 3 to 4 hours to get into 1000 & do a 2 stage polish.....the Baron/Bonanza Speedslope pictured(a pressurized Baron 58P)is a difficult shape, being compound curve. I spent two pretty full days on the windshield.
There is a saying from old artisan days......sculptures with flaws, whatever medium, that for one reason or another not pursued to end, would be filled & disquised with WAX.....antique bondoe!
For the sculptures that were near flawless, they would be known in the category of "SIN CERA"
"Without Wax"
"Without Wax"
I had to look up--"SIN CERA" to confirm my suspicion that it is the origin/whatever -of the word "sincere" -----Words mean things and meanings tend to change---
Today we may just say -- it's the "real deal" (or the like) and move on.:D
Impossible to load pix anymore, took 15 minutes to load these.
More "RICHEN"
lot of images were lost from original entries. composite photo shows my 68 B Bod post/bench Coronet...the Stearman belongs to a Friend
68 post coro ii.jpg majestic nomad.jpg 604 P 58.jpg Bettie jimi.jpg B at bases  valley.jpg aluminaughty 4.jpg View attachment 349814 GTO 2.jpg chalice stem  valley.jpg blade valley.jpg Beech 52 inch prop hub.jpg
This is the last warning you'll get from me on this thread....knock it off with the fighting. The latest contributions to this thread have caught the attention of all Staff now.
This Airplane, Martin B-26 Marauder, Used Curtiss Electrics....they are an almost 14 foot diameter swing...the blades are hollow steel, i imagine the P-47 blades are same....the 3rd pic is a Martin Executive conversion with Hamilton Standard 3 blade Oil Props, replacing the Curtiss Elecs. Ham Standards are aluminum alloy blades.
45K for for green tagged vintage CE blades is pretty reasonable as aviation prices go.
A Bombardier Challenger 604 is a contemporary Corporate mid size jet.....in 03, a replacement left side pane for cockpit slider window, which is a layered combination of Glass, Lexan & Mylar films....price of pane alone(not frame) was 85,000 @ that time.
No, i dont own an airplane...lmao.....getting to fly is my reward. When working on Aircraft, no move is made casually, but Slowly & triple checked.
The little Maule in my avatar is what i would like to get, an obvious STOL(short takeoff/landing) aircraft.....one of these early variants is roughly the same dollars as that Challenger 604 Pane.....some contrast. The Avatar pic is a 60's Maule advertisement.....from inside the hangar....the take off roll was about 35 feet.
  • Clearsthehangar.jpe
    Clearsthehangar.jpe
This is it....all non-relevant and back-biting comments are now being removed. Anyone else posting anything remotely close to being an issue with/towards another member (or BANNED/Past member) will be dealt with immediately, and will risk losing access to the site. Any and all future references to a car which may or may not have existed or its owner will also be dealt in the same manner. This fighting stops now.
No exceptions.
T
35 feet, pfffft!!!!
