Jtucker66
10.1 compression .030 440. came out of a 1977 motorhome. its been tanked so im sure all passages are nice.
dual quad 500 performers
champion 4 core 26 inch radiator factory mopar shroud and a flexalite solid mechanical fan.
160 degree thermostat
new mopar performance high flow water pump
front support is cut all the way for the entire radiator to be used.
the opening of the shroud is 20 inches and the fan is 18.25 inches. the fan is less than one inch from the radiator and is centered in the shroud.
i would say that the fan sticks out the back of the shroud(engine side) enough.
the timing is set at idle 12 degrees and still needs to be taken to the dyno to be fine tuned.
the car ran extremely hot with a 22 inc radiator we tried. it got up to about 235 by the time i got back from a test drive. ouch.
with the new 26 inch radiator and shroud the car ran about 200 to 205 for about an hour and through the neighborhood on the way home it hit 210. this was a 75 degree day and still just doesnt seem righr. at least im not in the danger zone but still......
thanks for any input.
