Camshaft ID
Racer1210
4:48 AM
Washington court house ohio
My engine builder passed away during build and I could not find the cam card. Can anyone identify this cam.
Larry
Here is my guess ..... but not sure?
COMP Cams Drag Race 323BR-8 Solid Roller Camshaft for Big Block Chrysler
Camshaft Series: Drag Race
Usage: Strip
Cam Type: Solid Roller
Grind Number: 323BR-8
Basic Operating RPM Range: 5,000-7,200
Intake Duration at .050 Inch Lift: 287
Exhaust Duration at .050 inch Lift: 287
Advertised Intake Duration: 323
Advertised Exhaust Duration: 323
Lobe Separation: 108
Intake Valve Lift: 0.69
Exhaust Valve Lift: 0.69
Lifters Included: No
Valve Springs Required: Yes
Assembly Lubricant Included: No
Camshaft Gear Attachment: 3-Bolt
Camshaft Material: Billet Steel
Engine Family: Chrysler 383-440 c.i. 8 Cylinder (1959-1980)
Lifter Type: Solid Roller
Usage: Strip
This was my thoughts as well. Called Comp yesterday, on hold waiting for next available tech for 70 minutes then the music stopped and recording came across that we are now closed and call back during working hours. Needless to say I was not impressed. Thank you jimbosride
Well got ahold of Comp and not there’s.
Sure looks like a Comp to me.
Check the lobe lift.
The 323-5 lobe has .460 lift.
I think you’ll find that’s what it is.
Spoke with Steve at Bullet Cams (guess he worked for comp for years back in the day) this afternoon. He confirmed it is a comp and determined it rather quickly plus was able to give me all the info on cam. Older grind and the tech dept at comp are uneducated on older numbers and they guaranteed me it was not there’s. My thoughts are they should be educated on all if they are going to be in tech but I’m old school when it comes to that stuff.
Thanks for the help guys.
