Checking Caster on Power Steering Equipped Vehicle?
Dibbons
2:31 AM
La Paz, B.C.S., Mexico
Does it make a difference if engine is running or not? What is the preferred procedure? Thank you.
Any of your alignment specs should not change with or without the engine running.
I popped something in my back around 1971 manually turning the wheels on a PS front end alignment. Chiropractor popped it back. :)
Mike
I've probably aligned over 3000 cars. Never had one running to check caster.
Doug
IIRC a non-PS car likes less caster which makes it easier to turn.
