Cleaning up an old intake
PlyGTXSat
3:13 PM
Huntsville
Got a edelbrock intake on my 340 that works perfect but is a little rough to look at. How are you guys cleaning up your intakes? Do i need to remove it and how complex are they to reinstall?
If the engine is running good, then don't take it apart. Try using some engine degreaser & letting it soak in there for a good long while at a do-it-yourself car wash.
I used Napa's aluminum brightener in the spray bottle...intake came out looking like new just gotta be careful it's strong stuff. Use only as directed..
Did you do it on the car?
No, I had it off at the time, but if you throw some plastic on the motor or towels or something to protect stuff I don't see why you couldn't do it with the intake on the engine.
Do it once and do it right! Otherwise any cleaning efforts you put in now will just have to be repeated again and again. Aluminum is VERY porous and absorbs all kinds of gunk over the years -- fuel, carb cleaner, etc. (that's where all the staining and discoloration comes from). Consider how much your time is worth and compare that against a couple hundred bucks getting it restored. Here's a few selections ...
... and a couple Before & After shots ...
You also get a FBBO discount. :D:D:D
View attachment 718682 View attachment 718683 View attachment 718684 View attachment 718685 View attachment 718686 View attachment 718687
View attachment 718692 View attachment 718691
How hard is it to pull off and put back on?
It takes a bit of time to remove the topside accessories and bolts but I wouldn't call it hard. Order your intake gaskets beforehand so the time the engine is hanging open is minimal. (Some people use a little RTV silicone on the short end seals.)
Done cheaply? Glass bead/sand blast and paint.
You’ll be back doing it again in a few years.
OR
Best bet, clean it the best you can & drop it off to be powder coated @CudaChick1968
These are my intakes in Alien Silver, the closest to the brand spankin new aluminum look I have found. I think I had 4 intakes done by her.
All work done by the beautiful Red head. LeAnna.
