mopar 3 B
- 10:58 AM
- Aug 25, 2014
- Kingsville, MO
Its hard on the synchros. The job of the synchro is to speed up or slow down the next gear being selected and the input shaft so that they match the speed of the output shaft. With the clutch engaged the input shaft speed cant be changed. You can get close and avoid grinding the gears but it still stresses the synchros. I bet there is quite a bit of brass shavings in your gear box oil.
That is what the gas pedal is for, matching gear speeds. There are no brass partials in my gear grease. Learnt how to shift no-synchro transmissions long ago with no clutch so why use it now.
