I have a temperature gun and just got another (to compare with) so I will do the test the next opportunity. I was aware of the bottom hose sucking flat as it happened to me 40 years ago with my 70 Challenger RT 383. The funny thing here is the picture above shows the old 22" radiator; it had a preformed bend in it at the stat neck. That hose would not fit the new 26" radiator. Tried to buy the same the same type of hose but no longer available. Although it went on fine, after the first local test drive, it sucked flat at the t-stat neck once it was heated. I replaced the upper with a conventional hose.
The belt is new and tight, doesn't slip or squeal.
When I flushed the motor before the new radiator install, very little of anything came out. The same is true when several drain downs for stat changes were done.
I have no heater / heater core to shut off or bypass. I wish I did. I got a factory A/C heater box years ago from a bone yard in California. Bought a new heater core for it also. Haven't installed it yet as access is difficult due to roll bar coming down inside front doors. I am not as flexible as I once was. Creature comforts would be nice as well as power steering which I also have. These are projects for the future. I will attach some photos of the old trans cooler (behind the new one), the new dual oil / trans cooler, the old 22" radiator and shroud and the (kink) that developed in the upper hose after the first warm up. Also the oil cooler thermostatic valve. I am not that savvy with some of this software and I hope I don't run into a problem uploading the pictures. By the way, the previous picture I sent can be expanded if you click on it and I assume these will work the same.[/ATTACH]
