Cooling my 360
USatC
11:00 AM
Montgomery
My 360 runs at 210-212 degrees at a dead stop at about 80 degrees here in Alabama. I’m concerned because once it gets really “Alabama hot” i might have some serious cooling problems. My current setup is a 190 thermostat, a stock shroud and radiator, and a five blade aftermarket fan. Any advice for keeping her a little cooler? I’ve read water wetter does a hell of a job but I’d prefer not to drop my 50/50 antifreeze ratio.
First. What is the condition of the radiator ? If that's not up to the task, nothing else will matter.
Also a 7 blade fan would draw more air.
If determined rad is good you can try dropping to a 180 t stat. My old iron headed 440 with no shroud 22” radiator and mechanical fan would climb to 220 in traffic 190-195 cruising.
70996027-2F93-4CCF-B6BB-979C6BB0706C.jpeg 0A0F8E23-42E0-44BA-B8CE-09CA66597965.jpeg
Get the radiator boiled out. 7 blade mopar fan with clutch. 180 stat. 1 gal coolant, the rest water.( you ain't freezing anytime soon down there) . 16 lb cap.
This may sound off the wall,but I have found
setting initial timing 3-4 degrees more advanced
can lower your temp.
Reason is the fuel available doesn't burn the
way it did when our cars were born.
Try it,just make sure you don't go to high &
cuase total advance to cause spark knock.
remove thermostat and run a radflush as recommended on bottle. if you have a old set up ( rad and engine)
and how close (or far) is the fan from radiator . , summit sell universal rad fan shrouds , or you could make one .
then flush it out good with water and like will robby said you could do 1 gallon antifreeze and rest water. and run a new 16 lb cap.
the 190 thermostat is fine. if its running over 200. 190 or 180 it s open anyway .it s decides minimum engine temp not max
i m running a flex fan on my car it s quick and sucks a ton of air. maybe a upgrade would be good
any pics???
Having the same issue with my 383.
I'm running a 180° thermostat, 6 blade fan and factory shroud. Gets hot enough in traffic to vapor lock...but not quite overheat. Tuned to 18° initial timing.
What I've discovered over the winter is (I've had my suspicions) the crank pulley is underdrive! It's approximately 4-1/8" dia. I've since located a pulley which is 5-3/4" but have read about factory crank pulleys up to 6-1/2".
Check your pulley set-up.
I had issues with my 440 in the Texas Summer heat. I said to hell with that and went all through the car to make sure I wouldn't have issues stuck in traffic on 100 degree days or when I went to Cruisin' the Coast in Mississippi. It's hot as hell there in October.
Sometimes we can over think issues like this. It shouldn't be too complicated to figure out though. Is this a new issue or has it been ongoing? Maybe you just got or built this car?
Check your timing. A little water wetter won't hurt but it's not a cure-all if you have an actual issue.
You may have to dig into it and see what you find. Might want to replace your thermostat. Cheap enough to do. Get one that, when it fails, it sticks open. You might want to run a 180, I have friends who run 160 and I run a 160, and a couple guys I know don't run one at all. With whatever temp you choose, you're really just saying I don't want my cooling system to work until it gets to that temp. If you choose a hot one, your cooling system would have to be working amazingly well to keep it around that temp. Probably not gonna happen.
Might be as simple as needing your rad rodded out at a radiator shop or it might be better to replace it. Just got to check it out and see if it might be full of deposits. If you replace it, you don't need to go crazy on a 4 row polished aluminum one. 2 or 3 row factory rads are fine. Cleanliness is important. Doesn't take much in the way of deposits to inhibit your rad's performance.
I run a 7 blade factory fan with a heavy duty fan clutch. Factory fan shroud. Factory stuff worked back then, should still work now, unless you've got some crazy build.
One thing that gets overlooked and I've learned can really help is to make sure the gaps between the rad and core support are sealed up. It's probably not going to make a gigantic impact but it does help. If you have gaps, well you'll pull air around the rad instead of through it. I found some foam weather stripping and sealed all those gaps up. There was a gap on my car that was too big for this foam and so I used a piece of angled aluminum on that area (because I have one of those fancy aluminum radiators). There's a piece of weatherstrip on my 72's hood that seals down across the top of the core support. Stuff like this can easily be missing and affect cooling in extreme temps.
Another thing is air. If you get an air bubble trapped, it'll run hot on you. I bought myself one of those spill-free funnels that allows you to get all the air out without **** going everywhere. I love that thing. I'll link one like it. https://www.summitracing.com/parts/lil-24680?seid=srese2&cm_mmc=pla-msn-_-shopping-_-srese2-_-lisle
I kept my factory gauge but I wanted to know exactly, at all times, what my temp is so I installed a mechanical temp gauge as well. My car runs 160 when it's cool out, but most of the time it's floating just below 180. In the hottest temps, it MIGHT get to 185 in stopped traffic. If I ever see it get above that, I know I am having an issue and it gives me more of a chance to figure it out as opposed to having an actual overheating problem. I actually installed the highest power flex-a-lite pusher fan on the front of my rad for just such an emergency. So far, that has been overkill because I never use the thing but it's there just in case.
When I was at Cruisin' the Coast I saw cars dropping like flies. Cars pulling in to shows hot as hell. Sitting on the side of the road overheated. I sat in the lines all week without a worry in the world. THAT was a good feeling.
You'll get it figured out.
On big blocks I tap the water pump recirc hole under the thermostat and plug with a 3/8" pipe Plug, with a hole drilled out to 1/8" in the plug. This sends more coolant to the radiator and will drop your temp down more than a few degrees.
Don't know if this applicable to a small block.
I installed a 3 row champion Raditor with a over flow tank. The over flow tank helps alot ended some 50/50 in there for reserve. Temp gauge doesn’t even get passed the middle.
