Cooling not worth a SH!T
Heating, Cooling & AC
  1. 5.7 hemi
    5.7 hemi FBBO Gold Member FBBO Gold Member
    12,088
    8615
    Dec 21, 2008
    ca
    Local Time:
    7:55 PM
    Clutch fan is better, and stick with a shroud.
    • Agree Agree x 1
    • Sweet5ltr
      Sweet5ltr Well-Known Member
      1,207
      602
      Oct 8, 2011
      Jacksonville, FL
      Local Time:
      7:55 PM
      I know, it prompted me to immediately remove the mechanical fan and re-install the Jaguar clutch fan with a shroud. 5% (+/-) power loss on a 600-hp engine. Well, it could be much more, just re-watched the episode, they shut it down at 5,000-5,200 RPM.
      Here is an article on how to change the thermal clutch fan engagement temperature range:
      http://midamericachevelles.com/tech/fan_clutch_adjust.pdf
      • Like Like x 1
      • Thanks! Thanks! x 1
      • SlinktRR
        SlinktRR Well-Known Member
        975
        455
        Aug 27, 2012
        NJ
        Local Time:
        8:55 PM
        I have a clutch fan in the garage, I’m now motivated to install it and see if it keeps the temps in a similar range as the mechanical. I’m still leaving power on the table, but hopefully less than 30hp.
      • Sweet5ltr
        1,207
        602
        Oct 8, 2011
        Jacksonville, FL
        Local Time:
        7:55 PM
        Great, the problem most of us had is the thermal clutches (that fit our cars) aren’t necessarily designed to fully engage under 195* F. When in reality, we would want it to fully engage around 180* F (or less) to keep engine operating temperatures down at idle (keep it as close to the thermostat or minimum desired operating temperature as possible). The Chevrolet article makes a good point, that even the reproductions aren’t rated the same thermal lockup temperature as the original.
      1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
        By continuing to use this site, you are consenting to our use of cookies.
