Outboards are capacitive discharge where most automotive are inductive both are electronic but apples and oranges.
He was on a road trip and the shop that tried to replace his distributor after the vehicle got towed off the highway disturbed the fuel line in the process and it went un-noticed until he was on the highway a day and a half later and flames were coming out from under the hood.Please explain the source of the engine fire.
Okay but I don't see the electronic ignition as the cause which seemed to be your indication earlier.He was on a road trip and the shop that tried to replace his distributor after the vehicle got towed off the highway disturbed the fuel line in the process and it went un-noticed until he was on the highway a day and a half later and flames were coming out from under the hood.
The orange box wires went behind the alternator right next to the fuel line (383) then over the lower right side of the engine.
The distributor had to be replaced because the counterweight springs failed and jammed everything up under the pick-up. Pieces were floating around everywhere under the distributor cap. The bearings were pretty tired as well.
What happened to Bob? Now that you mentioned it. I haven't seen any snarky comments lately. I mean if it's the Bob I'm thinking about.Bob would be stuck on, " WTH is a dizzy??"
Bob died a month back.What happened to Bob? Now that you mentioned it. I haven't seen any snarky comments lately. I mean if it's the Bob I'm thinking about.
