This may be stupid but I have thinking about it all day. I have a set of the Crane ductile iron rocker arms on my 440 with thick, hardened rocker shafts. The oiling holes in the shaft are on the bottom and grooved to oil the entire width of the inner rocker arm.
Inside the rocker is an oiling groove that covers 360 degrees. Now, here is where it gets confusing. There are two oil passages, one to the top of the rocker and one to the threaded adjuster. My guess is these oil the pushrod cup and valve tip. However, there are no corosponding oil ports in the shaft and I cannot see how oil gets to these passages!? Is there enough pressure to get oil into these along the shaft? Do I need to groove my shaft for these as I did for the lower oil port?
Grooved shafts...
You can see the port on top of rocker and on adjuster. These have no direct feed...
Grooved shafts...
