451Mopar
A roller cam F.A.S.T. build 383 stroker engine with 12+ compression is not going to have much in common with the cam for this.
Wrmrider summed it up well. Pick the better cam that fits. Set your bench mark high.
JMHO. If you want to start with a high bench mark I would call Lunati and have them change the 702 to a 110 lsa. Not the 112 Lsa shelf 702 cam..Lunati does that for free, only down side is paying for shipped, versus free shipping from the parts warehouses.
The Lunati’s is the more modern profile of the two cams your looking at. Probably similar in peak power, the difference would show up more in the average power.
451Mopar, LOL, that looks like the valve to piston marks on one of our 383s. Ours happened somewhere around 6500-7000 with a MP484 cam.
That little goof of bending the valves was the start down the path to my first 451 stroker. I originally bought the B-1 B/S heads to replace the 906 heads with the bent valves, but I really could not take advantage of the higher flow at high lift because of the piston to valve clearance problem of no valve reliefs in the pistons.
At the time (around 1992) I moved to a new city and did not know any machine shops, so I called Muscle Motors, talked to Chuck Senatore, and had them build me a short block to drop the heads on.
On the Lunati cams, I like them too, and they are usually a bit less expensive. The Voodoo series does use a 3-bolt cam gear for the timing set, vs the standard single bolt timing gear setup.
[/QUOTE]
