JR_Charger
I've currently sanded down to 1500 grit, is it worthwhile to make a 3000 grit pass on a driver?
I bought a used buffer that came with a 5" backing plate, but the instructions say to use a 6" plate. Will a 5" damage the machine? I'm doing smaller areas so the 5" will be o.k. if it doesn't damage the buffer.
How far will a foam pad go, before it has to be tossed?
