Hello all: First posting. I have a 66 Charger with a 361 engine. Basically all stock. Somewhat rare car in my neck of the woods. My issue is with the 8 & 3/4 diff. The diff. hosing is mounted off center. The diff housing is longer on the left side from the u bolts to the backing plate. There is more clearance between the inner tire sidewall on the left side than the rt. side. This cause the rt. tire to scrape the leaf spring on the inner sidewall on heavy slow speed turns where there is a lot of body roll to the rt. The springs and center bolts are ok and centered in the spring plates on the housing and the lower spring plate as well. I'm running 275 60 15 tires. I see nothing broken or shifted. I have been told by some that this normal. Just wondering what is out there for info, opinions. Thanks.
