Difference Between AC Fan Clutch and Non-AC Fan Clutch?
Fishtaco1969
7:40 PM
Phoenix Only
I have a dilemma, I have a 69 Charger RT 440 with air (all stock and original) that will be going thru an engine refresh soon. So I am looking and purchasing various parts, belts hoses, etc. When it comes to the fan clutch I am finding (Classic & Year1) have the fan clutch but for "non-AC" cars only, not for a car with AC. I didn't know there was a difference! Is there a difference? I 'm going to guess the one on there now is probably for a non-AC car as I purchased many years ago from Chief Auto Parts (now Auto Zone) in California. What are people doing today that have AC cars and need a clutch? Using the non-AC clutches? Thanks for your time and opinion. Tim
From what I found the original clutch is 2658456 which is a thermal drive unit for A/C applications. Non A/C cars got the standard clutch with no thermal drive from what I've seen.
I think the proper way to say that is a/c cars use a thermal fan clutch. That's that spring you see on the front of the clutch. I think it locks tighter when hot for the a/c. High Performance cars use a viscous drive fan to limit the rpm's for performance, noise and safety.
I think the thermal clutches are readily available from auto parts stores. I can't say how close to the OEM look they are. But someone on here will chime in with that info.
I have the thermal drive clutch from Tony’s Parts in my ‘69 GTX, with factory a/c. Just drove it to Carlisle and back for the Chrysler Nationals, and it worked perfectly.
One of my buddies said he couldn’t believe how much heat it was pushing out of the engine compartment just before I shut the car down at the hotel.
Also, some clutch brands have a heavy duty & a severe duty clutch. The HD clutch has more internal slippage, so that the fan spins at a slower speed. If you are chasing an overheat problem, use the SD clutch.
So if you don't have ac on your 440 use a torque controlled fan drive? I know mine was changed at a garage. It's a thermal drive fan clutch . I don't know what the original was. Used to roar when you started it up. I suspect fan clutch is worn Wiggles very slightly . But I think they put wrong one on .
There are 2 types of fan clutches: THERMAL DRIVE and TORQUE DRIVE. The thermal drive used were AC applications and has a temperature sensor in the front face and the TORQUE DRIVE clutch that dies not have a sensor in the face. The thermal drive unit adjusts it's slip RPM according to air temperature; the torque drive unit is calibrated to slip at a higher RPM for HP engine applications like HEMI and 6 barrel engines.
There are several after market brands...ORIGIONAL design, both types, (available thru Van's or Tony's parts) and Hayden brand....which, IMO, is a cheesecake design. But it's cheaper than OEM. PERSONALLY, the Hayden design looks aftermarket and I won't use it.......just my opinion.....
BOB RENTON
My car has factory ac and has a thermal clutch. I don’t see any part numbers on it. You can hear it big time when for instance you start the car after a heat soak.
