69'Net
I recently bought a 69 RR. I did an electronic ignition conversion on it, I posted on it in some other threads. The car fires up and idles really well, with good throttle response. I set the timing to 18 initial. The problem is it doesn't advance past around 22 for some reason. I have a brand new identical mopar proform that absolutely will not run in the car. I've kinda given up on the distributor as being faulty. I marked the old distributor rotor location, even found TDC again just to check. Won't fire. I put the old one back in and fires right up. Am I missing something here?
