Update, my car came with factory air, so you have to remove door sill trim, inner kick panels and on passenger side the vent accordion tube, then you can gain access to the upper hinge bolts on the inside. To my surprise the hinges already had been repaired one time with the larger pins and bushings so what I did is weld the holes that were oblong from wear and re drill them so all the play is gone.
