Doug’s Headers application frustration
ncrobb
5:36 PM
NC
Does anybody know the part number for a set of Doug’s Headers to fit a 1973 Road Runner with a small block, 4 speed, power steering if it makes a difference? I’ve tried to figure it out in their website, Summit’s website and even called Doug’s and gotten no where. Summit shows D453 to fit everything A, B and E small block but the comments all refer to A bodies.
Anyone have experience good or bad with these?
I have found that in MOST cases, if it fits an A body, it will fit a B or E. The C body cars are a different matter though.
Maybe Jegs is showing more details?
https://www.jegs.com/i/Dougs-Headers/776/D453/10002/-1
Is a mini starter the same as the size used on Dakotas?
I have seen mini starters in two sizes but there may be more. The Dakota seems to be the larger of the 2 "mini" starters.
Thanks folks. I’ll be in McDonough today and thought I’d stop in the Summit store and pick up a set.
Just for anyone wondering, the Doug’s D453 fit great. Driver side went on with no problem; I had to trim a casting nub off the bell housing on the passenger side. Car was up off the ground about 12” and I lifted the engine out of the mounts about 2”.
If I can hi jack will the D 453 fit my 71 plymouth satellite 360 with power steering power brake 904 with floor shifter.thanks
