i have had the carb apart several times.it is an 80508-1 and the pvcr,s were waaaaaay to big, .063 holes.it also had a secondary metering plate.i took the primary and secondary metering blocks off of a 4777-3 holley 650 double pumper, and used those.the pvcr,s were .0365 on the 650.no power valve in the rear.jetted it to 81 front and 85 rear.white secondary spring.car runs way better with this setup.but the idle is a little too rich,and i can smell unburnt fuel after a full throttle run.idle mixture screws are 1 1/4 turns out, and that is as far as i can turn them in for a good steady idle.my timing is perfect, 18 initial 38 total.all in by 2500 rpm. xe268h cam in a .040 over 383 with 452 heads.9-1 compression.my friend says that drilling the bleeds will wake it up,and i want to try it, but if it doesnt work im looking for a new main body. i do have an 850 double pumper that another friend let me try, but i havent rebuilt it yet.is it possible to use the 850 main body with the other metering blocks off the 750, and make it vacum secondary?just something i have been tossing around in my head.the 850 main body is allready drilled to .0321, and .078.what do you think?
