- 8:20 AM
- Jul 1, 2015
THANK YOU AGAIN.....the article about the Mazda twin chamber rotary engine is interesting. I remember, a few years back, where a neighbor was rebuilding a twin chamber rotary engine. It had two (2) spark plugs in the combustion chamber area, a leading plug and a trailing plug (Champion N-180B), presumably to insure complete combustion, plus a strange looking distributor. No cam, per say, just increases inlet port area, like lobe lift and port length like cam duration. The engine was complicated....each three lobe rotor had tip seals, side seals, apex side seals (all acted like spring loaded piston rings), plus rotor to output eccentric seals. The engine used lube oil, like a two stroke engine.......when running, it sounded strange. Putting it back together was complicated due to the various rotor sealing pieces...no real critical dimensions like a piston engine....I don't know about GMs connection but looks like mazda is concentrating on a come back.
Mazda 'very close' to a successful twin-rotor rotary engine
As a side bar, I thought GM was trying to adapt it (the rotary engine) to the Chevy Vega, to replace the 4 cylinder aluminum bore/block 2.3 liter engine or the other front engine rear drive compact car (can't recall the model name....Chevette Scooter ??)...1.6 liter engine....terrible car...cheap looking......JMO......
Anyway......thanks for the info about the rotary engine......
BOB RENTON
Looked to have 'young guy' rear suspension...... boing boing.
