62 Dart Convertible
I will be soon putting the sump on the 413 I'm rebuilding. It has a factory windage and I have 2 fel-pro gaskets to install. I will contact glue the gaskets on to the block and sump, what, if anything, should I put on the sides sandwiching the windage tray?
Also, I degreed the Lunati 10230703 cam. It recommends an ICL of 106deg (4 degrees of ground in advance). I measured 107deg. Is it worth the effort to correct it that 1 degree? (I have the offset bushes but I would need to drill the timing gear.)
