Fender Tag Decode
64lonske
11:03 PM
St Peter MN
Where can find someone or how do I decode a fender tag? Thanks
Feb 20 1964 scheduled production date, the 6004, along with 0220 is the shipping order number. 642 is Dodge polara 500 two door hardtop with a V/8. P5V is white and red vinyl bucket seat interior.PP1 is red paint, roof and body. I don't have info on the L.A. assembly plant, so I can' t do the rest.
THANKS
other than a build sheet is there anyway to identify what drivetrain the a 64' was built with?
If your car has the standard engine in it it will not be coded on the tag. In your case that would be a 318 poly. Different plants put the codes in different spots on the tag. The 5 could be a auto trans. The other numbers don't make sense as engine codes unless your car was built in Hamtramck.
I have some more information about this car now any help would be great.
What does the fender tag QR 09 mean?
IBM card shows the following:
1 = 0
2 = 5
3 = 0
4 = 8
5 = 4
6 = 0
7 = 5
8 = 2
9 = 7
10 = 1
11 = 5
12 = 7
13 = 6
14 = 8
15 = 1
16
17
18
19 = 6
20 = 4
21 = 2
22
23
24
25
26 = 6
27 = 6
28 = 1
29 = 7
30 = 4
31 = 9
32 = 8
33
34 = 5
35 = 1
36 = 1
37
38 = 5
39
40
41 = 9
42
43 = 2
44
45
46 = 0
47
48
49
50 = 0
51 = 6
52
53 = 1
54 = 2
55 = 3
56 = 7
57 = 6
58 = 6
59 = 2
60 = 5
61 = 6
62
63
64 = 3
65 = 1
66
67 = 6
68 = 4
69 = 4
70 = 5
71 = 1
72 = 7
73 = 0
74 = 9
75 = 7
76 = 6
77 = 0
78 = 5
79 = 0
80 = 7
I don't believe that IBM card jibes with that fender tag in post 1. The S0 numbers are different. Tag is 0220 6004. Card is 0508. 4052.
That would be my guess. I would check the body codes to confirm the IBM card is for your car. I'm sure it is but the body codes are a more accurate way to tell than the VIN. Body codes are harder to change than a VIN tag.
The radiator support, on the driver's side. Could be on the top or back of the support, and I believe there is the same code on the package tray. In your case the code is probably 4 5 0508 4052
will you decode this tag on my 62 savoy ? thanks, jim
3 speed floor yes 4 the digit 1----3121187582
