Flamethrower Coil Bracket
mopar73dge
12:17 AM
Connecticut
I just installed the new coil that comes with the FBO Ignition module, everything works great and the engine starts right up with one key jog with no gas, after sitting and heat soaking for several minuets. The 318 factory coil bracket is too small the new coil is larger... and I had to drill out the rear mounting hole oval with a vari bit to fit. I am looking for a bracket that fits the intake and the coil. Does one exist? I need a new one anyway the old coil plating is all worn off.
After some thought I decided to get a longer 10/32 screw to make up for the larger dia coil, paint the bracket with high heat aluminum paint and buff out, and raise one end of the bracket off the intake manifold with two or three thick SAE washers.
