moparnation74
Now we have the correct color vents....Lets get that puppy in there....
First I place the lower ends on the bolts to use as a pivot...Then I run the antenna and connect it to the radio(this is the way it was routed when I removed the dash) Next I install the bulkhead and four speed tach plug/wire. Then I route the vent cables through the opening(I do it this way because it is easier to adjust the cables on the dash versus on the heat box...
