Found a new project. Ram D250
So the engine is apart. #3/4 rod bearing were spun and melty. Journal on the crank looks like you would expect it to look. Also, #8 rod journal is grooved and catches a nail.
View attachment 1945617View attachment 1945618View attachment 1945619View attachment 1945620
Also, there is a tight spot when turning over the crank with a wrench. I haven't pulled the caps off yet but they are loose.
Block looks fine.
I can get a remanufactured short block for $1059, or do I have this machined and worked on?
That depends....
Do you trust the rebuilder?
Do you have a competent local machine shop/crank grinder that you trust?
Does it look like you'll need to bore it, or just re-ring?
In the old days, I would have just bought a crank kit from a rebuilder shop, and sized a couple rods (or bought a couple already done).
Longer boom doesn't help much without longer legs.
It would be factory longest setting. Problem is there isn't much meat on the extension so it was flexing down.
That depends....
I don't know any shops nearby and have only done a quick search in nearby cities. The bores look good so I would keep stock pistons and run a dingle ball hone with new rings.
What does a crank kit consist of?
I can get a remanufactured crank for $375, plus new main/rod bearings, rings to get it going.
Generally, the crankshaft (pick your size for mains and rods), bearings (again, pick your sizes), end seals and gaskets. You can also decide if you want to do a stroker at this point...
You'll need to have a machine shop work your block first though, so you know what size bearings you need to get for the mains (i.e. how far they had to bore the bearing surfaces to clean them up). Then you get your "0.0xx oversize" main bearings, for whatever size crankshaft journals you go with. Same deal if you're keeping the rods - have a shop clean up the journals and spec the oversize bearings for them, to match whatever journal size is on the crankshaft.
Or...depending on your budget and desire, you can get a "balanced assembly" of crank, rods, pistons, bearings, etc, that are all weight-matched and balanced as an assembly - but again, get your block work done first so you know what sizes you'll need (main journals, final bore size).
Reground crank, matching main and rod bearings. Google'd 318 crank kit, found one for $188, plus shipping and tax. I don't know if that's with or without a core.
Gotcha! The one I found for $375 shipped includes the bearings. I need to pull the crank, see what I have and take some journal measurements.
Should I replace the 2 rods on the spun journal? I haven't measured anything yet, but could the heat have ruined them? I'm assuming they need worked on for roundness and I was already budgeting new rods cap hardware.
They need to be resized and new bolts, or replaced, 100% ! I would do the third one on the rough journal too.
Personally, I'd replace.
Have a machine shop look everything over, machine the block, and give advice on rod/crank replacement after they're done. There's no way to diagnose stuff like this over the internet.
Do you want it to "work"? Or do you want it RIGHT?
I had an old jeep years ago, got it for $400. Dead miss on #1. Turns out, piston was shattered and in the oil pan. I dropped the pan, slapped in all new (standard size) bearings - rods and mains - pulled a used rod/piston assembly out of a core motor I had here, slapped it in #1 after a ball-hone and fresh (standard) rings, slapped in a hi-vol oil pump and tossed it all back together. Never dropped the crank, never pulled the motor, never pulled any pistons (#1 was already gone, so that one doesn't count really). Did it all in the truck, around the front diff.
I had a half-second of BRAAP every single time I started it from a combination of piston slap and rod bearing noise, but once that oil pump kicked in it was relatively quiet. And it ran for four years, daily driven, after that. "Right"? No, definitely not. "Worked"? Yup, I guess - for a $400 Jeep. Would I do it again that way? Nope.
Do it right. Find a machine shop. Have the block checked/line honed. Have the rods evaluated, and either properly sized, or replaced, based on what they find. Go from there.
Rock A has the crank and rods for decent price. $301 for crank and bearings, and $26ea for new rods. No core charge on crank. No size on crank. They have everything you need, Fel-pro gaskets, Hasting, Mahle, Speed-Pro rings. Looks like if you could get away with just honing it and new rings, crank, and a couple of rods, and gaskets you could rebuild it for around $500. They have Melling HV oil pump for $58, and maybe a timing chain, Cloyes $24. Maybe $600. That's pretty cheap rebuild on 318.
This is 100% a budget build. It would be just as cheap to get new rods. Like I said, nothing has been measured yet. I'm looking at a machine shop 3 hrs away to do block prep/clean and heads surfaced/cleaned.
I'm going to hone the bores myself and put the pistons back in. Block looks good and the bores are nice. New crank, bearings. I still need to get part numbers off the rods/crank so the right ones are ordered.
Nice. I like Rock Auto. Cheap is the plan. Once I'm able to measure the crank journal bores I'll contact someone about the crank.
I contacted EngineTech about their crankshaft and since the crankshafts are ground they send out oversized bearings to fit a stock sized block/rods. He said the clearance won't exceed.003". I ordered a plastigage kit to measure once I get it and go from there.
Make sure the plastigage is fresh....
