pearljam724
Found my oil leak. For a few days I was fearing it was the main seal. It’s distributor. Probably needs a new o-ring. I know it needs a proper gasket. Someone else used silicone and it’s not sealing very good. Hold down bolt, is plenty tight.
Can a original distributor be removed from a small block 69 Coronet without removing the hood ? Based on looking at it mounted. I believe it can. I would like to know for sure before I try it. If no one knows for sure and they have an original small block distributor around. I’d really appreciate a measurement from the spot it mounts to the block, to the tip of the shaft. This will give me a good idea how much clearance I need if no one knows for sure. Also, just to confirm. The oil pump drive should remain where it needs to be once I pull the distributor out, correct ? I realize what I have to do to reinstall the distributor. Just not sure if the oil pump drive will stay in there or come out with distributor ? If it does come with it, I expect not having the clearance then.
