The LCA rubber bushing is new, just the inner steel bushing is not "locked" on the pivot shaft.
There is no clearance, just the bushing and pin do not have an interference fit as the should have.
To me, this only causes the bushing to rotate around the pivot shaft instead of the rubber element taking the torsion. Should be no problem but after summer i will change them anyway.
The washer causes a more "fixed" negative camber angle between the LCA and the knuckle which increases my adjustability towards the negative side, exactly what i need in this case.
All other parts are renewed, Bilstein shocks, LCA bushing, added LCA reinforcement plate, upper and lower ball joint, strut rod bushings, new UCA with new bushings, tie rod assembly's and new wheel bearings.
There is no clearance in any component and is rock solid, just the usual play in the steering box which became the new PITA, but will get a new gearbox from FirmFeel or so to get that sorted...future story to come
@miller: I will get a measurement centre to centre of both arms and see what comes up.
These arms will be manufactured in a fixture with all correct dimensions but who knows, maybe someone was not paying attention on a Monday morning.
