Jeff 69
I have a 69 Road Runner and need to know if any one has a picture of where the ground strap goes. Thanks.
I think you just solved my fuel gauge problem. My gauge reads about half of the actual fuel level. Reads half full when full, then bottoms out at empty when the tank is actually half full. Had the tank out, sending unit out, grounded the gauge wire - read full. The sending unit ohms out correctly (10 to 75 ohms if i recall). Put it all back together and the gauge still reads wrong just as it did.
BUT, now I realize i dont have a ground strap... i just ASSumed the gas tank mounting straps and j bolts gounded the tank properly. I'm gonna rig something up quick tonight to test and I'll let you know.
Oh, and here's a source for the strap. http://www.carpartsdiscount.com/aut...el_sending_unit_ground_strap.html?3593=321915
Having no ground strap may be the issue but did you also verify your float was floating? Did you shake it to make sure there was no gas in it?
My aftermarket ground strap not worth a damn, so i fixed it like this, clip it around fuel line and tighten screw,works great and makes positive ground.
