XEO1-
We all know that the major mistake many people make are having oil severely above the fuel mark. But what if I was to tell you thr biggest mistake is overheating.
the engine begins to burn oil creating heat-condensation(don’t know the right word) that conducts into the engine block,crank,and rods bearings..
One of the worst things anyone can do internally inside a motor is have a unbalanced crank and rods spinning inside each 5 journals where the rods are thrusting the crank around in cockeyed rotations inside the 5 journals with vibration and heat absorption from higher oil contents burning at a higher rate because of a higher level of oil not being pumped continuously to cool down in the oil cooler- into every moving part and block heating is building up inside a unbalanced crank and rods…
but what I believe is having alittle added oil not to much in a unbalanced crank it might can help if I had a higher electric oil pump that works drastically harder to pump oil from its main level and back in damn fast while a damn good duel fan electric intercooler that’s cooling oil at a rapid accelerated rate I believe could help a amateur built motor properly operate…
why my dad is concerned so much but doesn’t necessary believe I know what I’m talking about which I usually don’t because I’m still learning about engines from dad but wanted y’all information on it…
it’s a topic in my head right now for a ideal motor for a unbalanced funnel crank that’s orbiting round and round a < it expands out word like this | producing a centrifugal spark via g ratios like a fighter plane feeling emense forces- meaning gravities density on match like flint burnt by friction fuel and gravity by forcing the hand to flick the match to burn…
