HEMI oil pump o ring help
kllerb69
9:35 PM
Long Isand
Getting redy to put my oil pump on and found that the o ring is missing dose any on e know were to get one that is not chinese ? 25 cent oring or 25g motor
Try Home depot,they have a large selection of o-rings.You can also try a local repair shop,the better shops also have a large selection.
Where on the Island are ya?,I'm in Great Neck:tongue8:
every o ring you get these days will be chinese made.
theres a guy up here in hawthorne new york that has them. hawthorne auto parts. also i found them at bel-aqua in new rochelle,ny
huge selection of every o ring size imagineable
I have acess to aircraft AN -8 and -10 nitril orings the -10 fit the groove nice but they are harder and could not be compressed in the hole the -8 was streched on the groove but fitted in the hole snug but I am afraid of it cracking over time and loose oil pressure. If some one has the diameter and thickness I could be shure it is sometimes the small things that get you.
thanks
Can't any one tell me the diameter and thickness of the o ring?
ps: AL i I hope you don't use home depo o rings in your new eng I had them crack after one year.
