JScherbik
I had just changed the spark plugs on my 68 Road Runner, and took her out for a ride. Coming off a stop sign, she sputtered and died. I tried to restart but the starter motor would not turn. The ignition switch did light up the oil light on the gauge panel, but did not start the car. Just nothing.
I went under the hood and found a light gage white wire running from the ignition coil to the firewall. At the firewall, it passes through a grommet as a lone wire. A small run of the insulation was melted to the cylinder head. I must not have notice that it fell into a hot area. The insulation looks as if it is melted but the wire looks like it should be intact. I am not sure what this wire is, or if it is the cause, but it's the only thing I can find that looks wrong.
Any suggestions would be appreciated!
Thanks,
Jay
Thanks,
Jay
