I'm Stalling on my 727 stall converter choice
Neal Zimmerman
11:58 PM
OK, I.m almost done with my 727 build for the 71 Charger, so I need to pick a stall converter. I have spent two days internet shopping until my eyes are crossed, seems everybody hates Boss Hogg, B&M, and TCI ( actually more like 50/50). Hughes seems to get decent reviews. NOTE : this is not a race car, just a street car poser machine. All these contradicting opinions make these support groups almost useless to me, but here goes anyway.
Car: 1971 Charger,
Engine: "mild" 1967 440 (very mild cam, HP manifolds, choice of several single or dual plane aluminum manifolds, 850 Thermoquad, whatever compression was stock in 1967 , electronic ignition.
transmission : 727 , I upgraded to 4 pinion front and rear planetary sets, A&A transmision bolt in "ultimate sprag", and a new A&A fully automatic valve body with mild shift kit.
rear end: 8.75 sure grip . I have several choices of ratio to play around with 3.23, 3.54, and 3.91.
So since everything is so mild I figure on a mild stall converter too. Somewhere in the 2500 range. This is also the area the guy at A&A suggested. I have also thought of just getting a stock replacement converter at autozone.LOL
What manufacturers am I leaving out? I remember in my youth Art Carr was a big name but haven't heard of him in years.
I would use a stock 340/383 10 3/4 convertor,
not the 11 3/4 version!
They are inexpensive and should get that stall
or close in your engine combo.
Your local transmission rebuilder may be a good option.
Mike
What GTX John said.
How would you go about finding the above mentioned convertor? From what I find it was called 2801764, but Im not finding much info on said convertor and who carries it?
Generally, referred to as a 764 converter.
You will need the correct flexplate for a 10 3/4 I have
one if needed. 11 3/4 will not work.
BIG +1 for Frank Lupo at Dynamic Converters in Delaware
I agree with the stock Hi Stall 10 3/4" used in 340's. It'll be darn close to what you want. And there cheap.
