beanhead
Easily Offensive
Not sure what happened....rebuilt my demon carb last weekend because it had a little leak, plus it sat in the garage for 10 years before I used it. Had a feeling my intake seal wasn't perfect either so I re-did that while I was there(found oil getting into the ports)- 440 with edelbrock heads&intake, comp 274xe cam, compression 9.5-10...motor used to pull a wavering 14" vacuum at idle and required some feathering on cold starts. Since the carb/valley pan re-do, this thing has been awesome...fires right up, crisper throttle...even sounds stronger, and getting a fairly steady 16-17 at idle...until today. Pulling in the garage it began to stumble and could barely idle, vacuum down to under 10, hardly runs now...float levels good but changing carb settings didn't help..what the frick.Timing set at 20-ish idle, hits all in at 38... Don't have time to monkey with it until the weekend so I'll check the plugs, ignition stuff, do the spray-for-leaks test but what a bummer...ok, mostly just venting here..any thoughts?
I know, right?
