odwan12
Guys!
I had a few fitment questions regarding the K-member in my 65 Satellite.
1ST After a review of this k-member and several pulls of measuring tape i have identified this k-member to be a 73-up b-body k-member according to schumacher's identification page.
so, not only does this pose a problem as far as the motor's position in the car (height and longitudinal) but also a fitment issue as far as headers.
I am using a low-deck B block (451) and have already scoured the forums regarding the fitment issues when it comes to low-deck blocks and headers. It seems like it's no dice. BUT apparently this k-member sits the motor a little higher. BUT schumacher remedies this positioning for proper geometry by instructing to cut a little off of the mount and drilling new holes for a lower position.
SO that leads me to future fitment issues of headers, oil pan, possibly oil pump..
2ND
Im aware that the original 62-65 b-body k members sat the engine forward approximately 3"
I am still in the body work stages of my project, having taken the entire car apart and want to weld my new 4 speed hump in this car within the next week SO I am concerned about this k-member sitting the motor back too much to where the shifter mechanism doesn't line up correctly with the natural position of the hump on the floor pan.
I want to go ahead and get the subframe connectors done this week as well.
3rd
this should be my last question/statement.... How will all of the aforementioned effect the crossmember for my 4speed. I am aware that there were different mounts for early b's and later b's.... being that i have a newer k-member messing up my original geometry. should i go ahead and try a 65 style mount first or the later 66-up mount for proper alignment.
FINALLY
Id like to try and figure these problems out now, so when this thing is done the body work and painted a beautiful deep deep black, I'm not cutting, grinding, etc... any wise words from you mopar gurus are appreciated.
Thanks in advance gentlemen
Very Respectfully,
aaron:angryfire:
2ND
3rd
FINALLY
Very Respectfully,
aaron:angryfire:
