Gunner1
A lot of cams have some advance built into them.  A 104LS on a 102 ICL is gonna build some brutal mid range.  My 400 Chevy ran a 105 on a 99ICL. It was amazing. Can’t wait to see the outcome.
			I like to look at piston to valve with checking springs installed at the #1 cylinder. Bolt the head on with few bolts snugged up and the gasket installed. Then you can move the valves with a finger. Bring it to 10 ATDC. Leave the exhaust valve out and look thru the exhaust port at the intake pocket clearance. You could probably do the same and leave the intake out to check the exhaust but at 10 BTDC. If it's all good put the two #1 cylinder spring back on and send it.
Doug
Summit (moroso I think) has them.My valvespring tool requires the head off of the block. So can I snug down on my Cometic gasket, back it off again, then re-install on the same gasket. I do have a single left over FelPro .040 head gasket i could also use, so the Cometic is fresh when I torque it down.
also, where can I get springs suitable for this Process? I would think literally anything that will hold the valve closed is fine, what have you used in the past?
lastly, what is the min clearance I’m looking for?
No problem with using the Cometic. The current motor was done that way. I've even reused them 3 times after running. Using the Fel-Pro would be close enough. Your actual clearance would even be greater with the thicker Cometic. I just got generic hardware store springs about 1"diameter 2" long. Just so they hold the retainer up.My valvespring tool requires the head off of the block. So can I snug down on my Cometic gasket, back it off again, then re-install on the same gasket. I do have a single left over FelPro .040 head gasket i could also use, so the Cometic is fresh when I torque it down.
——When ordering pushrods, my Thoughts are to stay away from oil-through units, as a way to divert more oil to the bottom end. My lifters do oil through the cup, but I’m thinking that’s where I would like the lifter galley flow to end. The rockers have an oiling hole at the pushrod side to spray onto the cup & ball. I think that will be sufficient for that area.
Thoughts?
I was going to mention, guess I should have. Melling HV pump. Milodon pan and 3/8” tube pick up. No other mods made to the oiling. Oil pressure is 60-70, rock solid and zero issues. I also run a #4 line to my oil pressure gauge so it’s instantly accurate.Doug and Mike, what oil pump do you guys use? And how elaborate is your oiling modifications? My setup is pretty rudimentary, with simply a Melling HV pump, and deep pan and windage tray. Everything else is stock. Thus my thoughts of limiting oil to the upper end. This thing is gonna spin, and I don’t want to starve the bearings.
May be overkill. Melling HV pump body and gears. Indy cover single line external feed. Swinging pick up. Johnson Crank scraper. Charlies trap door pan. Screen windage tray.
Doug
I used 440 Source Main Caps plus their Girdle on my 505" in my 66 Coronet, over 150 runs AND 10.04 at 130.51. No problems. I sold it to a fellow in Denmark several years ago and he has been driving it to car shows, etc for years with no iissues.I‘m happy to report that I‘ve decided on a path for a refresh of the LemonWedge bullet that will hopefully take place this coming off-season. This will be a budget friendly deal, but should still yield some strong results. The current 452” 400 will be stroked to 471 (4.382 x 3.915). Ill be needing some help with questions and verification of various things here & there, so I’m starting this thread as a place to reach out to guys with experience where mine is lacking.
Build plan: I’ll be re-honing the current bore and reusing my current flat top 1.322 pin ht Icon pistons. They will be hung on new 6.700 rods, and we will offset grind my current forged RB crank out to 3.915, or whatever puts me at 0 deck. Compression should end up just a tad north of 11:1. Heads will be untouched for now; MCH ported and prepped Stealths. Intake and carb will also be the current M1 and 1000cfm annular 4150.
I decided on stepping up to a solid roller this time around, and have already been working with Howards on valvetrain parts. My order is already in for the following cam, lifters, and valvesprings:
Howards Cams 722323-08 Howards Cams Steel Billet Mechanical Roller Camshafts | Summit Racing
Howards Cams 91735
Howards Cams 98816 Howards Cams Pacaloy Mechanical Roller Valve Springs | Summit Racing
Luke at Howards was great to work with. We ran into a stumbling block with the springs, but he was able to find a path that works with new “+.100” retainers to get me the required nose pressure while working with my existing valves Installed ht. With my current 1.6 ratio rockers, lift will be pushed to .660, after lash. I’m pretty excited about this rowdy new valve train combo.
First question I have is for anyone that has worked with a set of 440Source Aluminum Main Caps: My block is already studded, and currently utilizes stock caps. Even though this isn’t a long stroke, I want to strengthen the bottom end of my 400 block to deal with the extra strokes leverage at 6800rpm, which is what I currently trap at and shouldn‘t change. My machinist says that new caps will likely need a mainline bore, a thrust machining process, and machining of the block register. He’s telling me these processes are expensive and push my budget. He doesn’t feel the aluminum caps are necessary.
440source claims their caps should be usable with a simple mainline hone, and possibly some sizing of the caps register width.
Q: who is right? and are the aluminum caps a worthy investment for a build targeting approx. 625hp.
