- 2:19 AM
- Nov 21, 2008
- In GTXtacy Illinois
So as not to steal racer-x's thunder, i figured i would make my own thread...
looking to get a lift for my garage, but i have a low ceiling, and i want to be able to pull a car in alongside the GTXer even if im working on her.
(see pic below)
i saw a bendpak one-post that would have been good, but of course, they dont make it anymore!! :angry9:
http://www.asedeals.com/portable_lift.html
so ive found three other options, one of which Ma Snart mentioned on racer-x's thread.
here's Ma's suggestion:
http://www.asedeals.com/portable-car-lift-gen.html
which would work, but there are two problems; one is that there is a bar that goes across the bottom of the car for the opposite side lifting pads (which is not a deal breaker), and the second is the feet of the lift go under the car, so you cant really get all the way under car (which could be a deal breaker)
the second one is the max-jax:
http://www.asedeals.com/two-post-lifts-MaxJax.html
which is "portable" but i dont want to have to keep taking the bolts out of the ground (which may weaken the concrete taking the bolts in and out everytime i want to move it. (i realize they bolt into sleeve anchors)) also, it only has three points where you can lock it in with steel bars, and i have measured, measured, measured, but with my luck, the third position (highest) will still be hair high and the car will hit the ceiling. otherwise, it would be perfect
lastly, i found a twinbusch lift (Euro):
http://www.twin-shop.de/shop/index.php?cPath=1
which is a one poster, and it looks like the bendpak, but i couldnt find anyone here in the States that stock and/or warranty them. (i did contact the company directly, but haven't heard back yet). so this one is a distant third.
in any case, i would be using 2 trans jacks, one under the k-member and one under the pumpkin, to stabilize and add a bit of safety.
opinions and suggestions are greatly appreciated!
Thanks!
Mar
(see pic below)
Thanks!
Mar
