Lifter tick on fresh build
Which side is the 'Tick' on?. Remember the drivers side gets oil first then the passengers side.
It sounds like it's coming form both sides, more towards the rear of the engine, and maybe I f'd up cuase I didn't soak the lifters before installation, but I did prime rotate a number of times and even primed and rotated it several times before initial start up
So what's the conclusion on your preload settings.
Like I said before, don't know if you read the reply, but I believe I set the at .020" ,it's been over a year since I assembled it, I have only 30 mild miles on it, and with my job I am only home for about 20 hours total, so much time to mess with it yet, gotta spend time with family on my short time at, home. I'm going to check it when I get some time but I'm also kind a thinking the oil pump might be a issue as with a mechanical gauge it was only getting 40 to 45 psi ?
No, my bad. I was thinking of another lifter thread. Also I believe you're right , you should have more pressure. Take the pump off and check it out
I don't see any issue with a stock pump making 45 psi. 45psi Isn't causing a lifter tick.
Ok guys i do appreciate the help and I've gotten it down the road, I know this doesn't enply to my sattelite, but I came here for some advice cuase this forum is more active then the trucks only and I figured car or we are all a mopar family so I'm going to copy what I posted on the track forum and hope I can maybe get some ideas or answers,
Ok guys i do appreciate the help and I've gotten it down the road, I know this doesn't enply to my sattelite, but I came here for some advice cuase this forum is more active then the trucks only and I figured car or we are all a mopar family so I'm going to copy what I posted on the track forum and hope I can maybe get some ideas or answers, View attachment 1852187
Honestly I'd get it running with a good carb first, then maybe try and reinvestigate making a thermobog work after
