longer rear wheelstuds
cherokeechief79
11:44 AM
usa
i need longer wheelstuds for the rear of my 67 coronet wagon.i got new wheels and tires and i thought i was correct with the backspace at 5.5.but they hit the leafsprings.ill need to run about a 3/8 spacer.i already bought new lugnuts and would rather not go with very long studs and an open lugnut.is there one i can get locally that will work and be around 3/8 or so longer?also can i press these in without removing the axle?its an 8 3/4 rear
You can bang out the old studs with a hammer. I have never seen TWEEN studs.
You need the longer studs......
Can cut them down if need be.
Try Dorman 610-446. They are about .35 inch longer than stock. They also have a .010 larger knurl. They are listed for Jeeps. I just bought them for my front disc brake conversion.
thanks....i made one similar for a ford axle i had to do.worked like a charm.
its nice not just stacked washers
